It is currently Tue May 12, 2026 10:49 pm
 Post subject: Ignition coil question
PostPosted: Sun Jan 01, 2006 11:50 am
Contributor
I'm converting my '64 Valiant 225 to an electronic ignition that consists of a Mopar Performance kit with the distributor reworked to use stock springs.
The question I have is about a new coil I've had on the shelf for a few years. It's a Borg Warner part and it's actually made in the USA. The box is marked "E31" and the coil itself has 27290 stamped on it and a note to use with an external resistor only.
I checked the Borg Warner website and they list the E31 along with several other part numbers and the way I read it, they all fit dozens of car models, including lots of Mopar models from '55 to '86. The 27290 number does not come up when I use their part number search function.
A post on another website asks about this same part number for an old Corvette and a response says it's only for use with a points-style distributor.
Can anyone tie the 27290 part number to a Mopar electronic ignition usage?
PostPosted: Sun Jan 01, 2006 1:22 pm
E31 is a more or less universal 12v can-type ignition coil for use with ballast resistor. No real advantage using this coil instead of the one presently on the car.
PostPosted: Sun Jan 01, 2006 2:18 pm
Contributor
I'm only trying to avoid potential breakdowns....the original Mopar coil is still on the car after 41 years...at least it's a Mopar coil and I know it hasn't been changed in at least 21 years.
I guess I'll just throw the new one in the trunk and see how long the old one will last.
Thanks Dan, at least I know it's an acceptable replacement.
PostPosted: Sun Jan 01, 2006 6:27 pm
SSRN National Champion
Aint Dan Cool :D :D :D
Using A Tennessee Moonshiner To Burn A Bagel
PostPosted: Sun Jan 01, 2006 6:52 pm
The old one won't last long. Mine lasted a week after converting to electronic ignition. You need a coil for electronic ignition.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
