It is currently Wed Jul 15, 2026 6:04 pm
PostPosted: Sat Oct 19, 2002 12:07 pm
I´m restoring 66 Valiant. Exterior just painted dark turqoise metallic, as it was originally. Interior colors are cold metallic and light tan. Engine color (block) has been red. But I Would like to know more about the colors. How about valve cover or intake manifold. And exhaust manifold and pipe - including muffler?
The list will go on: shock absorbers, torsion bars, rear axle, transmission-box, etc...
Could someone help with the tip for my ORIGINAL "color hunting?"
Little-Jake from Finland, Europe
jarpit@luukku.com
PostPosted: Sat Oct 19, 2002 3:55 pm
: I´m restoring 66 Valiant. Exterior just painted
: dark turqoise metallic, as it was
: originally. Interior colors are cold
: metallic and light tan. Engine color (block)
: has been red. But I Would like to know more
: about the colors. How about valve cover or
: intake manifold. And exhaust manifold and
: pipe - including muffler?
: The list will go on: shock absorbers, torsion
: bars, rear axle, transmission-box, etc...
: Could someone help with the tip for my ORIGINAL
: "color hunting?"
: Little-Jake from Finland, Europe
Sorry we did not get to your earler post, thing have been busy....
The Sl6 engine was a red / orange color through 1967, in 1968 it change to "Mopar Blue"
The intake manifold and valve cover was also the engine color. The factory did not paint the exhaust manifold or exhaust pipes.
The transmission bellhousing was "mostly" painted the engine color, the transmission, suspension parts and rearend were not painted, these items would rust and / or get greasy.
Muffler was also a naturual metal color and the torsion were "dip painted" a semi glossy black.
Hope that helps,
PostPosted: Sat Oct 19, 2002 5:07 pm
: Sorry we did not get to your earler post, thing
: have been busy....
: The Sl6 engine was a red / orange color through
: 1967, in 1968 it change to "Mopar
: Blue"
: The intake manifold and valve cover was also
: the engine color. The factory did not paint
: the exhaust manifold or exhaust pipes.
: The transmission bellhousing was
: "mostly" painted the engine color,
: the transmission, suspension parts and
: rearend were not painted, these items would
: rust and / or get greasy.
: Muffler was also a naturual metal color and the
: torsion were "dip painted" a semi
: glossy black.
: Hope that helps,
: DD
: Yes it helped, thank you. I´ll be back with new problems in the near future, I´m afraid...
Little-Jake
jarpit@luukku.com
PostPosted: Sat Oct 19, 2002 8:44 pm
Hey Doc,
My car, a '68 Dodge Dart, actually came with a red/orange engine. The sale date on the owner's manual says January 1968 delivery date. Is it possible that my engine has the '67 style crank? This was always a concern of mine...don't want to buy manual transmission parts that won't swap in.
Pat
: Blue"
: glossy black.
: Hope that helps,
: DD
pwd22@drexel.edu
PostPosted: Sat Oct 19, 2002 10:10 pm
: Hey Doc,
: My car, a '68 Dodge Dart, actually came with a
: red/orange engine. The sale date on the
: owner's manual says January 1968 delivery
: date. Is it possible that my engine has the
: '67 style crank? This was always a concern
: of mine...don't want to buy manual
: transmission parts that won't swap in.
: Pat
Does the block have 3 or 5 freeze plugs? What is the casting number on the block? As far the manual trans., all is the same except for the flywheel.
PostPosted: Sat Oct 19, 2002 10:21 pm
:Yes it helped, thank you. I´ll be back with
:new problems in the near future, I´m afraid...
:Little-Jake
Nothing to be afraid of with a Slant Six, these engines are pretty forgiving. One this is for sure, I have never broke one with a can of spray paint! ; - )
Keep asking questions and don't be afraid to try stuff, that is how you learn.
PostPosted: Sun Oct 20, 2002 5:55 am
: Does the block have 3 or 5 freeze plugs? What
: is the casting number on the block? As far
: the manual trans., all is the same except
: for the flywheel.
: DD
Doc, I have a '68 V200, red motor, 5 freeze plugs, cast # 2806830-3, scheduled build date of May 9 1968, assembly plant was Hamtrack, MI. Maybe cars assembled at the Los Angeles plant in '68 used blue motors. I have a '68 Signet,(bracket car project), with a red motor but it's at my shop so I can't check the build date and plant.
Cecil
ceh52@quik.com
PostPosted: Sun Oct 20, 2002 2:36 pm
The block has 3 freeze plugs, but I'm unsure of the casting number (wrote it down but can't find it--hard to see it under my pipes).
Pat
: for the flywheel.
: DD
pwd22@drexel.edu
PostPosted: Sun Oct 20, 2002 4:08 pm
: "color hunting?"
My father purchased a 66 Valiant, brand new. I remember the block, valve cover, intake, and oil pan were all red, and the accessories were black.
lasergame@prodigy.net
PostPosted: Mon Oct 21, 2002 6:55 am
: for the flywheel.
: DD
My '68 Dart 270 was built at Hamtramck with a 5-plug motor - all red. I like the red quite a bit, and you can still get spray cans of it from Mopar Performance.
PostPosted: Mon Oct 21, 2002 1:18 pm
: My '68 Dart 270 was built at Hamtramck with a
: 5-plug motor - all red. I like the red quite
: a bit, and you can still get spray cans of
: it from Mopar Performance.
: Lou
I checked my '68 Signet, red motor, 5 plug, #2806830-2, Hamtrack, built June 20, 1968. Lou, do you know of another vendor for red besides Mopar Performance? I've used their orange and it's slow to dry in FL humidity. It's still tacky more than a week later. I switched to Plasticote and it's dry in an hour or two. The orange didn't match each other but it was close enough for my low standards.
Cecil
ceh52@quik.com
PostPosted: Mon Oct 21, 2002 2:09 pm
: I checked my '68 Signet, red motor, 5 plug,
: #2806830-2, Hamtrack, built June 20, 1968.
: Lou, do you know of another vendor for red
: besides Mopar Performance? I've used their
: orange and it's slow to dry in FL humidity.
: It's still tacky more than a week later. I
: switched to Plasticote and it's dry in an
: hour or two. The orange didn't match each
: other but it was close enough for my low
: standards.
: Cecil
Can't help you with the paint, although sometimes I've just used Ford Red from local parts store (whatever brand). Mopar engine red is the correct color, as far as I know.
PostPosted: Mon Oct 21, 2002 3:48 pm
Doc,
Is the color change in 1968 a light blue or a dark blue?
My '69 Dart came with a light blue/green color on the engine. I'm not sure if it is the original color or if someone shot it with a F-O-R-D (four letter word; starts with "F") color. Please advise.
Darster69
ldhale@granitecity.com
