It is currently Wed May 20, 2026 2:31 pm
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 116 17 18 19 2081 Next
PostPosted: Thu Jul 01, 2021 8:12 pm
Yes it is hard to see the timing marks on the romac's without changing the color.
Good work!
PostPosted: Fri Jul 02, 2021 4:09 am
Looking Good!
Will
PostPosted: Sat Jul 10, 2021 7:35 pm
Going thru some parts I bought from Jim Cox.
I have a set of Isky and Erson pushrods.
The Erson pushrods are shorter.
Anyone have any Erson catalog or a Cox parts list?
Erson E917402.
Need to know if the publish a length measurement.
The Isky's say 9.953 length.
Or would anyone have 1 of the old DC pushrod kits?
I need 1 pushrod if I use my old DC set.
The clown who stole my Lancer bent 2 and I have only found 1 new on since then.
PostPosted: Sat Jul 10, 2021 7:55 pm
Have smith brothers make you one.
You'll have it before the end of the week.
PostPosted: Sat Jul 24, 2021 5:54 pm
Good call Greg, Smiths is making one now and if it's correct I will get them to build a set.
Here is the engine as of today.
Intake has to come off to drill the Holley pattern.
The intake has the early AFB pattern only.
PostPosted: Sun Jul 25, 2021 3:34 am
Beautiful.
PostPosted: Sun Jul 25, 2021 5:13 am
Online
Looking Great Stan! Soon the sound of Slant 6 music will be heard!! :D :D
PostPosted: Sun Jul 25, 2021 10:31 am
Is your intake missing the carb mounting plate?
PostPosted: Sun Jul 25, 2021 3:50 pm
Maybe..maybe not. Sure is hard to see on those low rez images :D
PostPosted: Sun Jul 25, 2021 5:46 pm
The manifold is a fabricated intake based on a 59 aluminum one barrel.
There is a large plenum welded to the outboard portion of the intake after cutting and welding.
The length is between a Weiand and a hyperpack.
Here are some more low res images.
It was professionally welded using parts I have no idea where they came from.
I think the idea was to retain carb heat but that was not functional.
The manifold was drilled today for the Holley pattern and the carb is now mounted.
PostPosted: Sun Jul 25, 2021 7:32 pm
Awesomeness!
PostPosted: Mon Jul 26, 2021 9:15 am
Everything is looking great!!!!
Will
PostPosted: Mon Jul 26, 2021 2:37 pm
Well that's why it's hard to see. 'cause it's not there.
Nice Custom parts.
Gettin it ready for Clay city to be rowin' the gears!
PostPosted: Sat Jul 31, 2021 4:24 pm
i had the same trouble with that damper! called and they told me it had a .005" interference fit! local machine shop told me that was alot! so i had to sand it until it pressed on!
PostPosted: Sat Jul 31, 2021 6:29 pm
Terry, I was surprised it was so tight.
A little sanding with a sanding wheel and it went of easy.
Still using a bolt in the crank end.
